WiFi Connection Troubleshooting
WiFi problems can be frustrating but are usually solvable. Here are some common things to check when having WiFi connectivity issues.
1. Verify SSID and Password
Ensure the SSID (network name) and password are correctly entered in the device's settings. This might seem basic, but it's a common oversight and a good starting point for troubleshooting.
If you're having trouble with connecting to WiFi and you've verified that your SSID and password have been entered correctly, consider removing any odd characters and/or spaces from your SSID and password. Spaces and special characters in either the SSID or password may sometimes lead to difficulty establishing a connection.
2. Confirm 2.4GHz Band Compatibility
Konnected devices operate only on the 2.4GHz WiFi band (802.11b/g/n) and not on the 5GHz band. Ensure that the router or access point you're attempting to connect to supports and has enabled the 2.4GHz band. If you have a feature on your Router called 'Smart Connect', you may need to disable it.
3. Don't use a Guest Network!
Do not use a Guest Network for your Konnected device. Individual devices on guest networks, by design, cannot talk to other devices on the network and usually can only access the internet. Using a guest network will make the Konnected device inaccessible to the Konnected mobile app and other smart home hubs on your network.
4. Check Router Channel Settings
The Konnected device may have issues connecting to routers set to channels 13 or 14, which are not legal for use in some regions, such as those governed by the FCC (United States). Adjusting the router to operate on a different channel, ideally setting it to auto, can resolve this issue.
5. Security Protocol Compatibility
Your network should use WPA for network security and authentication, as this is the most compatible with Konnected devices and smart home devices in general.
6. WiFi Signal
If your device is experiencing a weak or unstable WiFi connection, this can significantly impact its performance. To address low WiFi signal strength, consider the following steps:- Positioning. Ensure that your device is within a reasonable range of the WiFi router. Walls and other physical obstructions can weaken the signal.
- Mesh Networks. Upgrading your home WiFi to a mesh network system can help boost the signal in areas far from the main router.
- Interference: Other electronic devices and appliances can interfere with WiFi signals. Try to minimize the number of obstructions and interference sources between the device and the router.
7. Other Considerations
- Network Outages: If there's a network connectivity issue, Konnected devices will automatically reboot as a failsafe measure. Occasional reboots are normal, and the system is designed to quickly restart and resume seamless operation.
- Firmware Updates. Ensure your device's firmware is up to date for the best performance.
