title: Frequently Asked Questions (FAQ) | Help & Support
description: A list of our frequently asked questions.
[Skip to content](https://support.konnected.io/frequently-asked-questions-faq#main-content)
[Submit a Ticket](https://support.konnected.io/kb-tickets/new) [Customer portal](https://support.konnected.io/tickets-view)
1. [Help & Support](https://support.konnected.io/)
2. [Frequently Asked Questions (FAQ)](https://support.konnected.io/frequently-asked-questions-faq)
# Frequently Asked Questions (FAQ)
- [How to tell a USB charge-only cable from a USB data cable](https://support.konnected.io/how-to-tell-a-usb-charge-only-cable-from-a-usb-data-cable)
- [What size kit do I need?](https://support.konnected.io/what-size-kit-do-i-need)
## Garage Door Opener
- [Security+ 3.0 and White Learn Button Garage Openers](https://support.konnected.io/security-3.0-and-white-learn-button-garage-openers)
- [Does the Konnected Garage Door Opener Support Ethernet?](https://support.konnected.io/does-that-garage-door-opener-gdo-support-ethernet)
- [Can the Garage Door Opener trigger the Garage Door?](https://support.konnected.io/can-the-garage-door-opener-trigger-the-garage-door)
- [What Smart Platforms Does The Garage Door Opener Support?](https://support.konnected.io/what-smart-platforms-does-the-garage-door-opener-support)
- [How is the Smart Garage Door Opener different from using a momentary switch with a relay?](https://support.konnected.io/how-is-the-smart-garage-door-opener-different-from-using-a-momentary-switch-with-a-relay)
- [Which Garage Door Openers are compatible with Konnected GDOs?](https://support.konnected.io/what-garage-doors-does-your-garage-door-opener-work-with)
- [Is Your Garage Door Opener a Standalone Solution?](https://support.konnected.io/is-your-garage-door-opener-a-stand-alone-solution)
See less ▼
## General
- [Does Konnected work with Z-Wave technology?](https://support.konnected.io/does-konnected-support-zwave)
- [LED Indicator Light Colors and Meanings](https://support.konnected.io/led-indicator-lights-colors-and-meanings)
- [Understanding the Difference between Alarm Panels and Add-On Boards](https://support.konnected.io/alarm-panel-vs.-alarm-panel-add-on)
- [What's the Difference Between the Conversion Kits and the Interface Kits?](https://support.konnected.io/whats-the-difference-between-the-conversion-kits-and-the-interface-kits)
- [What is the Difference Between the Alarm Panel Pro and the Alarm Panel?](https://support.konnected.io/what-is-the-difference-between-the-alarm-panel-pro-and-the-alarm-panel)
- [What Kind of Wire Should I Use for Wiring Wired Security Sensors?](https://support.konnected.io/what-kind-of-wire-should-i-use-for-wiring-wired-security-sensors)
- [How to Replace Your Keypads with a Tablet for Smart Home Control](https://support.konnected.io/how-to-replace-your-keypads-with-a-tablet-for-smart-home-control)
See less ▼
## Pre-Purchase Guides
- [How to Get Started with Smart Home Automation](https://support.konnected.io/how-to-get-started-with-smart-home-automation)
- [Choose Your Smart Home Platform](https://support.konnected.io/choose-your-smart-home-platform)
- [What do you need to use the Konnected Alarm Panel?](https://support.konnected.io/what-do-i-need-to-use-the-konnected-alarm-panel)
- [Konnected Devices in General](https://support.konnected.io/konnected-devices-in-general#main-content)
    - [Intro to Konnected](https://support.konnected.io/konnected-devices-in-general#intro-to-konnected)
    - [Power](https://support.konnected.io/konnected-devices-in-general#power)
    - [WiFi and Networking](https://support.konnected.io/konnected-devices-in-general#wifi-and-networking)
    - [Firmware and Updates](https://support.konnected.io/konnected-devices-in-general#firmware-and-updates)
    - [Security Best Practices](https://support.konnected.io/konnected-devices-in-general#security-best-practices)
- [Alarm Panel](https://support.konnected.io/alarm-panel#main-content)
    - [Installation Guide Table of Contents](https://support.konnected.io/alarm-panel#installation-guide-table-of-contents)
    - [Wiring and Connection Guides](https://support.konnected.io/alarm-panel#wiring-and-connection-guides)
    - [Interfacing In-parallel with a Traditional Alarm System](https://support.konnected.io/alarm-panel#interfacing-in-parallel-with-a-traditional-alarm-system)
    - [Alarm Panel Pro](https://support.konnected.io/alarm-panel#alarm-panel-pro)
    - [6-Zone Alarm Panel & Alarm Panel Add-on (discontinued)](https://support.konnected.io/alarm-panel#6-zone-alarm-panel-alarm-panel-add-on-discontinued)
    - [Standalone Alarm System](https://support.konnected.io/alarm-panel#standalone-alarm-system)
- [GDO blaQ](https://support.konnected.io/gdo-blaq#main-content)
    - [Getting Started with the GDO blaQ](https://support.konnected.io/gdo-blaq#getting-started-with-the-gdo-blaq)
    - [Platform Integrations](https://support.konnected.io/gdo-blaq#platform-integrations)
    - [Device Features](https://support.konnected.io/gdo-blaq#device-features)
- [GDO White](https://support.konnected.io/gdo-white#main-content)
    - [Garage Door Opener White Installation and Setup Guide](https://support.konnected.io/gdo-white#garage-door-opener-white-installation-and-setup-guide)
    - [Detailed Wiring Guide](https://support.konnected.io/gdo-white#detailed-wiring-guide)
    - [Garage Door Opener v1 Installation and Setup Guide](https://support.konnected.io/gdo-white#garage-door-opener-v1-installation-and-setup-guide)
- [Accessories](https://support.konnected.io/accessories#main-content)
    - [Backup Batteries](https://support.konnected.io/accessories#backup-batteries)
    - [Sensors](https://support.konnected.io/accessories#sensors)
- [SmartThings](https://support.konnected.io/smartthings)
- [Home Assistant](https://support.konnected.io/home-assistant)
- [Hubitat](https://support.konnected.io/hubitat#main-content)
    - [GDO White](https://support.konnected.io/hubitat#gdo-white)
    - [Legacy drivers](https://support.konnected.io/hubitat#legacy-drivers)
    - [Alarm Panels](https://support.konnected.io/hubitat#alarm-panels)
    - [Troubleshooting](https://support.konnected.io/hubitat#troubleshooting)
- [Control4](https://support.konnected.io/control4)
- [ESPHome](https://support.konnected.io/esphome#main-content)
    - [ESPHome](https://support.konnected.io/esphome#esphome)
    - [Konnected Device API](https://support.konnected.io/esphome#konnected-device-api)
    - [openHAB](https://support.konnected.io/esphome#openhab)
- [Matter](https://support.konnected.io/matter)
- [Frequently Asked Questions (FAQ)](https://support.konnected.io/frequently-asked-questions-faq#main-content)
    - [Garage Door Opener](https://support.konnected.io/frequently-asked-questions-faq#garage-door-opener)
    - [General](https://support.konnected.io/frequently-asked-questions-faq#general)
    - [Pre-Purchase Guides](https://support.konnected.io/frequently-asked-questions-faq#pre-purchase-guides)
- [Troubleshooting](https://support.konnected.io/troubleshooting#main-content)
    - [Hardware issues](https://support.konnected.io/troubleshooting#hardware-issues)
    - [Frequently Asked Questions (FAQs)](https://support.konnected.io/troubleshooting#frequently-asked-questions-faqs)
    - [Device Discovery](https://support.konnected.io/troubleshooting#device-discovery)
    - [Konnected Device Firmware & Software](https://support.konnected.io/troubleshooting#konnected-device-firmware-software)
    - [Legacy: HASS Install](https://support.konnected.io/troubleshooting#legacy-hass-install)
    - [Legacy: Wiring Info](https://support.konnected.io/troubleshooting#legacy-wiring-info)
    - [Garage Door Opener](https://support.konnected.io/troubleshooting#garage-door-opener)
- [Orders, Shipping & Returns](https://support.konnected.io/orders-shipping-returns#main-content)
    - [Refund and Return Policies](https://support.konnected.io/orders-shipping-returns#refund-and-return-policies)
    - [Shipping Information and Policies](https://support.konnected.io/orders-shipping-returns#shipping-information-and-policies)
- [Safety Information](https://support.konnected.io/safety-information#main-content)
    - [Standards & Certifications](https://support.konnected.io/safety-information#standards-certifications)
    - [Warnings & Disclosures](https://support.konnected.io/safety-information#warnings-disclosures)
- [Products](https://support.konnected.io/products#main-content)
    - [Depreciated Support Articles](https://support.konnected.io/products#depreciated-support-articles)
- [FAQs](https://support.konnected.io/faqs#main-content)
    - [Additional Wiring Guides](https://support.konnected.io/faqs#additional-wiring-guides)
- [SmartThings Steps](https://support.konnected.io/smartthings-steps)
- [Noonlight](https://support.konnected.io/noonlight)
- [Alexa](https://support.konnected.io/alexa)
- [Google Home](https://support.konnected.io/google-home)
