Security+ 1.0 Wall Controls and GDO blaQ
A purple or red/orange learn button identifies an original Security+ 1.0 garage door opener. On these openers, a failing wall control can cause odd behavior, missed commands, or a door that seems to open without a command. Before changing the protocol setting on your GDO blaQ, identify the wall control by model number or take a clear photo of it.
If you have a digital smart wall control
Leave the digital smart wall control connected and set GDO Protocol to Security+ 1.0 with smart panel. This mode listens to the wall control's status polling.
Use this setting with a compatible digital smart wall control such as the LiftMaster 889LM. Do not switch to the standard Security+ 1.0 setting just because you are troubleshooting missed commands or unexpected door movement. Confirm the wall control model first.
Choose a replacement wall control
If your existing wall control has failed or is no longer available, use these options in order:
- LiftMaster 889LM: This digital smart wall control is the recommended replacement. Leave it connected to the opener and use Security+ 1.0 with smart panel on the GDO blaQ.
- LiftMaster 78LM: This analog wall control is a compatible alternative. Door operation works, but the physical Light and Lock buttons on the 78LM do not work while the GDO blaQ is connected. Use the standard Security+ 1.0 setting.
- Simple momentary push button: This is the least expensive option, usually less than $10. It provides basic door control only. Use the standard Security+ 1.0 setting.
The LiftMaster 888LM was discontinued years ago and is no longer available new. If you already have one, it will usually work with the GDO blaQ in Security+ 1.0 with smart panel mode. Rare power problems have been reported with some older 888LM controls, so treat it as a legacy option rather than a recommended replacement.
Troubleshoot odd or unexpected behavior
- Find the learn button on the opener. A purple or red/orange learn button indicates Security+ 1.0.
- Take a clear photo of the wall control and its model number before changing the GDO protocol setting.
- If the wall control is a digital smart panel, leave it connected and select Security+ 1.0 with smart panel.
- If the wall control is a LiftMaster 78LM or a simple momentary push button, select Security+ 1.0.
- If the setting matches the wall control and the problem continues, the wall control itself may be failing. Replace it with one of the options above or contact Konnected Support and include the photos and model number.
For example, one Chamberlain HD900D-era opener showed odd behavior after its Chamberlain 041A6318 / LiftMaster 398LM smart wall control failed. That control is discontinued, so the LiftMaster 889LM is the recommended replacement.
For general opener compatibility, see Which Garage Door Openers are compatible with Konnected GDOs?.
