title: Flashing Firmware with Command Line Tools
description: Use the CLI to flash new firmware on a Konnected device
[Skip to content](https://support.konnected.io/flashing-firmware-with-command-line-tools#main-content)
3. [Firmware and Updates](https://support.konnected.io/konnected-devices-in-general?hsLang=en#firmware-and-updates)
# Flashing Firmware with Command Line Tools
## Use the CLI to flash new firmware to your Konnected device
The latest Konnected firmware binaries are distributed for free and available to download from GitHub or from our website. These are the "factory default" firmware builds and are the same generic firmware images that are pre-loaded on Konnected devices at the factory.
#### Download Firmware
Download the bin file for your product and desired platform:
| **All products** (ESPHome platform)*Latest generation* (recommended) | [konnected-esphome Releases (GitHub)](https://github.com/konnected-io/konnected-esphome/releases) |
| Alarm Panel Pro (legacy firmware) | [Alarm Panel Pro releases](https://support.konnected.io/alarm-panel-pro-release-notes?hsLang=en) |
| Alarm Panel (legacy firmware) | [konnected-security Releases (GitHub)](https://github.com/konnected-io/konnected-security/releases) |
| GDO White v1 (legacy firmware) | [garage-door-opener Releases (GitHub)](https://github.com/konnected-io/garage-door-opener/releases) |
#### Install Python
Python 3.7 or newer is a prerequisite. If you're not sure if you have python installed, open a Terminal window and type:
python --version
 or
python3 --version
If you have python installed, this command should output `Python 3.12.3` or similar. If not, install Python before continuing. Download Python for [Windows](https://www.python.org/downloads/) (be sure to select *add Python to PATH* option) . Mac users can use the Python that comes with Xcode command line tools by running `xcode-select --install` in a Terminal window.
#### Install esptool
[esptool](https://docs.espressif.com/projects/esptool/en/latest/esp32/installation.html) is the command-line tool provided by Espressif for communicating with the ESP chips in Konnected devices.
On Mac, install esptool using [Homebrew](https://brew.sh/)
brew install esptool
On Windows or Linux, install esptool using pip:
pip3 install esptool
Verify that esptool is installed correctly:
esptool version
#### Flash the downloaded firmware
In Terminal, run the `esptool write-flash` command from the directory that you downloaded the firmware binary:
esptool --port=COM3 --baud 460800 write-flash --flash-mode dio 0x0 konnected-firmware-X-X-X.bin
The *--port* option is your serial port. Usually like *COM3* on Windows or */dev/cu.usbserial-XXXX* on Mac.
The *konnected-firmware-X-X-X.bin* is the full path to the downloaded firmware binary.
The output should look something like this:
esptool v5.1.0Connected to ESP32 on /dev/cu.usbserial-2130:Chip type:          ESP32-D0WD (revision v1.1)Features:           Wi-Fi, BT, Dual Core + LP Core, 240MHz, Vref calibration in eFuse, Coding Scheme NoneCrystal frequency:  40MHzMAC:                3c:8a:1f:1f:a9:c4Stub flasher running.Changing baud rate to 460800...Changed.Configuring flash size...Flash will be erased from 0x00000000 to 0x0008efff...Wrote 585344 bytes (334167 compressed) at 0x00000000 in 8.7 seconds (538.0 kbit/s).Hash of data verified.Hard resetting via RTS pin...
