title: Door Toggle Relay Trigger on the GDO blaQ
description: Using an external relay or dry-contact to trigger the garage door with the GDO blaQ.
[Skip to content](https://support.konnected.io/door-toggle-relay-trigger-on-the-gdo-blaq#main-content)
2. [GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en)
3. [Device Features](https://support.konnected.io/gdo-blaq?hsLang=en#device-features)
# Door Toggle Relay Trigger on the GDO blaQ
## Use a dry-contact relay or an external trigger to toggle the garage door open and closed.
The GDO blaQ extra inputs ① or ② can be configured to accept an external dry-contact trigger to toggle the garage door. This can be useful for integrating a Security+2.0 garage opener with an external system that has a relay or dry contact output.
When enabled, a momentary trigger of your relay or external dry-contact (up to 3 seconds) will trigger the *toggle* action on the garage door.
### Wiring the Relay Trigger
1. Connect one side of the relay output to ① or ②.
2. Connect the other side to either of the ⚪️ white terminals.
### Enabling the Door Toggle Relay
#### Using the Konnected App
1. ![Screenshot\_20250929\_150505\_Konnected](https://support.konnected.io/hs-fs/hubfs/Screenshot_20250929_150505_Konnected.jpg?width=280&height=282&name=Screenshot_20250929_150505_Konnected.jpg)From *My Devices*, tap on your GDO blaQ and tap *Settings \> Extra Input / Output*
2. Tap on *Extra #1* or *Extra #2* and select *Door Toggle Relay*
3. Choose *Normally Open* or *Normally Closed* for *Relay Type*
#### Self-managed ESPHome firmware
Add the `gdo/gdo-external-toggle.yaml` package to the list of packages in your GDO blaQ ESPHome config and set `pin` to *$input1* or *$input2*.
packages:  remote_package:    url: https://github.com/konnected-io/konnected-esphome    files:    - path: packages/gdo/gdo-external-toggle.yaml      vars:        pin: $input1        inverted: "true"
