Connecting the Alarm Panel Pro with Ethernet
Connecting the Alarm Panel Pro by Ethernet is as easy as plugging it in!
The Alarm Panel Pro ships with Ethernet enabled by default.
- Plug it in. Plug one end of an Ethernet cable into the Ethernet port on your Alarm Panel Pro. Connect the other end to an available port on your router or network switch.
- Power up. If you're using a Power over Ethernet (PoE) capable router or switch, your Pro board will power on automatically. Otherwise, use the included power adapter to power the device.
- Confirm connection. The Pro board should automatically obtain an IP address from your router and connect to your network. You can now discover it using the Konnected App
