California Proposition 65 Warning
WARNING
The Konnected Alarm Panel, Konnected Alarm Panel Pro, and/or Konnected Alarm Panel Interface Module can expose you to chemicals including nickel/nickel compounds, which are known to the State of California to cause cancer, di-n-butyl phthalate (DBP), which is known to the State of California to cause birth defects or other reproductive harm, and lead/lead compounds which are known to the State of California to cause cancer, birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
California Prop. 65 Details
The likelihood of the product containing the following chemicals known to the State of California to cause cancer or reproductive toxicity is:
High Likelihood
| Chemical name | Where used |
| Antimony oxide (Antimony trioxide) | Fuses, Resistors |
| Bisphenol A (BPA) | Resistors |
| Carbon black | Capacitors, Resistors, Switches |
| Lead and lead compounds | Connectors, Diodes, Fuses, Resistors, Switches, Terminal Blocks |
| Nickel and nickel compounds | Capacitors, Connectors, Diodes, Fuses, Resistors, Switches, Terminal Blocks |
| Titanium dioxide | Resistors |
Medium Likelihood
| α-Methyl styrene (alphaMethylstyrene) | Transceiver Modules |
| 2-Methylimidazole | Capacitors, Inductors |
| Butyl benzyl phthalate (BBP) | USBs |
| Beryllium and beryllium compounds | Capacitors, Inductors |
| Cadmium and cadmium compounds | Capacitors, Inductors, USBs |
| Di-n-butyl phthalate (DBP) | Transceiver Modules, USBs |
| Di(2-ethylhexyl)phthalate (DEHP) | USBs |
| Gallium arsenide | Capacitors, Inductors, LEDs |
| Lead and lead compounds | Capacitors, Inductors, LEDs, Transceiver Modules, USBs |
| Nickel and nickel compounds | Transceiver Modules |
| Perfluorooctanoic acid (PFOA) | Capacitors, Inductors |
| Thorium dioxide | Capacitors, Inductors |
The information on this page was prepared by Enviropass.ca under contract for Konnected. Certificate No. 210208.
