title: ESPHome Zone to GPIO Pin Mapping
description: Internally, the Konnected application references pins instead of zone numbers. Zone numbers are labeled sequentially for user-friendliness,
[Skip to content](https://support.konnected.io/zone-to-gpio-pin-mapping#main-content)
2. [ESPHome](https://support.konnected.io/esphome?hsLang=en)
3. [Konnected Device API](https://support.konnected.io/esphome?hsLang=en#konnected-device-api)
# ESPHome Zone to GPIO Pin Mapping
Internally, the Konnected application references *pins* instead of zone numbers. Zone numbers are labeled sequentially for user-friendliness, but the internal pin numbers map to the GPIO index of each I/O port on the ESP chip.
Konnected's ESPHome *base packages* set [substitutions](https://esphome.io/guides/configuration-types.html#substitutions) or variables that make it simpler for you to reference zones or outputs in your ESPHome configuration.
### Konnected Alarm Panel (ESP8266) Zone to Pin Mapping
Used for the original NodeMCU based Konnected Alarm Panel, Konnected Alarm Panel v2 and other products using the ESP8266 based WiFi chip.
| **Zone #** | **ESPHome variable** | **NodeMCU Pin #** | **GPIO #** |
| 1 | $zone1 | D1 | GPIO5 |
| 2 | $zone2 | D2 | GPIO4 |
| 3 | $zone3 | D5 | GPIO14 |
| 4 | $zone4 | D6 | GPIO12 |
| 5 | $zone5 | D7 | GPIO13 |
| 6 | $zone6 | RX or D9 | GPIO3 |
| OUT or ALARM | $out or $alarm | D8 | GPIO15 |
### Alarm Panel Pro (ESP32) Zone to GPIO Mapping
The Alarm Panel Pro uses the ESP32­-WROOM­-32D chip from Espressif and the following zone to GPIO mapping.
| **Zone #** | **ESPHome variable** | **GPIO #** |
| 1 | $zone1 | GPIO4 |
| 2 | $zone2 | GPIO2 |
| 3 | $zone3 | GPIO15 |
| 4 | $zone4 | GPIO13 |
| 5 | $zone5 | GPIO18 |
| 6 | $zone6 | GPIO14 |
| 7 | $zone7 | GPIO33 |
| 8 | $zone8 | GPIO32 |
| 9 | $zone9 | GPIO36 |
| 10 | $zone10 | GPIO39 |
| 11 | $zone11 | GPIO34 |
| 12 | $zone12 | GPIO35 |
| ALARM1 | $alarm1 | GPIO12 |
| OUT1 | $out1 | GPIO23 |
| ALARM2 or OUT2 | $alarm2 or $out2 | GPIO5 |
