What Do the WiFi Error Codes Mean?
This article provides an overview of WiFi error codes, offering valuable insights for diagnosing and resolving connection problems.
If you're having trouble with your WiFi connection, you may want to create a help-log which can assist you in identifying a reason for your connection problem.
Below is a table of WiFi disconnect codes and their corresponding reasons. For more information and the original source of this table, please visit this site.
wifi.eventmon.reason
Table containing disconnect reasons.
| Disconnect reason | value |
| wifi.eventmon.reason.UNSPECIFIED | 1 |
| wifi.eventmon.reason.AUTH_EXPIRE | 2 |
| wifi.eventmon.reason.AUTH_LEAVE | 3 |
| wifi.eventmon.reason.ASSOC_EXPIRE | 4 |
| wifi.eventmon.reason.ASSOC_TOOMANY | 5 |
| wifi.eventmon.reason.NOT_AUTHED | 6 |
| wifi.eventmon.reason.NOT_ASSOCED | 7 |
| wifi.eventmon.reason.ASSOC_LEAVE | 8 |
| wifi.eventmon.reason.ASSOC_NOT_AUTHED | 9 |
| wifi.eventmon.reason.DISASSOC_PWRCAP_BAD | 10 |
| wifi.eventmon.reason.DISASSOC_SUPCHAN_BAD | 11 |
| wifi.eventmon.reason.IE_INVALID | 13 |
| wifi.eventmon.reason.MIC_FAILURE | 14 |
| wifi.eventmon.reason.4WAY_HANDSHAKE_TIMEOUT | 15 |
| wifi.eventmon.reason.GROUP_KEY_UPDATE_TIMEOUT | 16 |
| wifi.eventmon.reason.IE_IN_4WAY_DIFFERS | 17 |
| wifi.eventmon.reason.GROUP_CIPHER_INVALID | 18 |
| wifi.eventmon.reason.PAIRWISE_CIPHER_INVALID | 19 |
| wifi.eventmon.reason.AKMP_INVALID | 20 |
| wifi.eventmon.reason.UNSUPP_RSN_IE_VERSION | 21 |
| wifi.eventmon.reason.INVALID_RSN_IE_CAP | 22 |
| wifi.eventmon.reason.802_1X_AUTH_FAILED | 23 |
| wifi.eventmon.reason.CIPHER_SUITE_REJECTED | 24 |
| wifi.eventmon.reason.BEACON_TIMEOUT | 200 |
| wifi.eventmon.reason.NO_AP_FOUND | 201 |
| wifi.eventmon.reason.AUTH_FAIL | 202 |
| wifi.eventmon.reason.ASSOC_FAIL | 203 |
| wifi.eventmon.reason.HANDSHAKE_TIMEOUT | 204 |
