title: Set up Hubitat Safety Monitor with Noonlight
description: Noonlight can alert emergency responders when Hubitat Safety Monitor triggers an intrusion or smoke/fire detection event. Noonlight works in Hubitat like a switch or siren/strobe so setting it up is a
[Skip to content](https://support.konnected.io/set-up-hubitat-safety-monitor-with-noonlight#main-content)
2. [Noonlight](https://support.konnected.io/noonlight?hsLang=en)
# Set up Hubitat Safety Monitor with Noonlight
Noonlight can alert emergency responders when Hubitat Safety Monitor triggers an intrusion or smoke/fire detection event. Noonlight works in Hubitat like a switch or siren/strobe so setting it up is as simple as *turning on Noonlight* under *Siren Alerts* or *Light Alerts*.
1. Go to *Apps* in the Hubitat main menu.
2. Click on *Hubitat Safety Monitor* in your apps list. If you haven't set up Hubitat Safety Monitor yet, set it up first by clicking *Add Built-in App*.
3. Under *Configure Hubitat Safety Monitor*, click into each monitoring rule and select *Siren Alerts*. Check the checkbox next to the *Noonlight* device.
   ![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32004246036originalRore1qqayOa1Zl4UtjqOtiZD9LLJqlsF_Q.png)
4. Click *Done* to save changes.
Dismissing an intrusion or smoke alarm event will NOT dismiss the Noonlight alarm. If there's a false alarm you **can only cancel the alarm by communicating your Noonlight PIN to the dispatcher**. If Noonlight cannot get in touch with you by phone, they will send help to your address.
**Next Step:** [Trigger a Test Alarm](https://support.konnected.io/test-noonlight-and-hubitat-integration?hsLang=en)
**See Also:** [Hubitat Safety Monitor official documentation](https://docs.hubitat.com/index.php?title=Hubitat_Safety_Monitor)
