title: Powering When a Plug is not Nearby
description: How to Power a Konnected Alarm Panel when a wall outlet is not nearby.
[Skip to content](https://support.konnected.io/providing-power-to-konnected#main-content)
3. [Power](https://support.konnected.io/konnected-devices-in-general?hsLang=en#power)
# Powering When a Plug is not Nearby
Sometimes, particularly in Alarm Panel installations, a household power outlet is not nearby the alarm panel wiring location. The makes it challenging to plug in the Konnected device with a power adapter.
Usually, if you are replacing an existing traditional alarm panel, there will be a wire providing power from a transformer on a nearby or adjacent wall. Identify this wire and unplug and remove the existing transformer (these AC transformers CANNOT be used to power Konnected devices!)
### Reusing the Existing In-wall Wiring![](https://support.konnected.io/hs-fs/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32007389588originalMiu1h1DTwJ3X8yRSkhDJ0vLgVSVDbMDlIA.png?width=1200&height=417&name=s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32007389588originalMiu1h1DTwJ3X8yRSkhDJ0vLgVSVDbMDlIA.png)
1. **Disconnect the Power** to the alarm panel before you begin. Usually, this means unplugging a power adapter and unplugging the backup battery. The power brick may be in another area of the house (closets & attics are often hiding places)
2. Disconnect the wire on both ends from the unplugged transformer. Disconnect the wires from the AC terminals on the old board.
3. Use a [DC terminal screw adapter (female)](https://konnected.io/collections/in-stock-now/products/dc-power-screw-terminal-adapter?variant=1574222299156) on the plug side. Use a [DC terminal screw adapter (male)](https://konnected.io/collections/in-stock-now/products/dc-power-screw-terminal-adapter?variant=15787778703433) on the security panel side.
4. Plug in the Konnected power supply - plug in the terminal screw adapters on both sides.
