title: My siren just crackles. Now what?
description: If you hear only a static or crackling sound when the siren is activated, unfortunately your siren is probably just a dumb speaker.
[Skip to content](https://support.konnected.io/my-siren-just-crackles.-now-what#main-content)
3. [Hardware issues](https://support.konnected.io/troubleshooting?hsLang=en#hardware-issues)
# My siren just crackles. Now what?
If you hear only a static or crackling sound when the siren is activated, unfortunately your siren is probably just a dumb speaker. It requires a *siren driver* module to modulate the siren sound. Most of the time the siren driver module is built-in to the old alarm panel, so you can’t use it with Konnected.
### In this case you have a few options:
1. The easiest and cheapest option is to replace the siren with a newer, inexpensive siren. The [Honeywell WAVE-2](https://aax-us-east.amazon-adsystem.com/x/c/QnhZYhXwaxo3MpuOcRfVJDUAAAFiMJ_-aAEAAAFKAehtpwg/https://www.amazon.com/Honeywell-WAVE-2-Two-Tone-Siren/dp/B0006BCCAE/ref=as_at/?creativeASIN=B0006BCCAE&imprToken=vLJECtX1jTllzS5HNcy8cA&slotNum=0&ie=UTF8&qid=1505166694&sr=sr-1&keywords=honeywell+wave-2+two+tone+siren&linkCode=w61&tag=konnected-io-20&linkId=88d72b7628a4189e80951c64eefcc34a) is my favorite because of its incredible value.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/ws-na.amazon-adsystem-Apr-17-2023-09-41-53-3768-PM.comwidgetsq)](https://konnected.io/collections/shop-now/products/honeywell-wave2-two-tone-siren)[Honeywell WAVE-2 Two Tone Siren](https://konnected.io/collections/shop-now/products/honeywell-wave2-two-tone-siren)
2. You also can buy a standalone siren driver module. In this case, just connect the Alarm +/- to the driver, and your speaker wires to the driver. Here are two options:
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/ws-na.amazon-adsystem-Apr-17-2023-09-41-54-8577-PM.comwidgetsq)](https://aax-us-east.amazon-adsystem.com/x/c/QnhZYhXwaxo3MpuOcRfVJDUAAAFiMJ_-aAEAAAFKAehtpwg/https://www.amazon.com/Elk-ELK-100-100-Siren-Driver/dp/B001943WRO/ref=as_at/?creativeASIN=B001943WRO&imprToken=vLJECtX1jTllzS5HNcy8cA&slotNum=3&s=hi&ie=UTF8&qid=1505166922&sr=1-1&keywords=siren+driver&linkCode=w61&tag=konnected-io-20&linkId=f30a872fde219f2ba34dda1645de1ba6)[Elk 100 Siren Driver](https://aax-us-east.amazon-adsystem.com/x/c/QnhZYhXwaxo3MpuOcRfVJDUAAAFiMJ_-aAEAAAFKAehtpwg/https://www.amazon.com/Elk-ELK-100-100-Siren-Driver/dp/B001943WRO/ref=as_at/?creativeASIN=B001943WRO&imprToken=vLJECtX1jTllzS5HNcy8cA&slotNum=4&s=hi&ie=UTF8&qid=1505166922&sr=1-1&keywords=siren+driver&linkCode=w61&tag=konnected-io-20&linkId=3d70e29e82f5d1f860f13e9c796c2b02)
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/ws-na.amazon-adsystem-Apr-17-2023-09-41-56-4012-PM.comwidgetsq)](https://aax-us-east.amazon-adsystem.com/x/c/QnhZYhXwaxo3MpuOcRfVJDUAAAFiMJ_-aAEAAAFKAehtpwg/https://www.amazon.com/Siren-Driver-2-Channel-6-12Vdc/dp/B003XZZ3WO/ref=as_at/?creativeASIN=B003XZZ3WO&imprToken=vLJECtX1jTllzS5HNcy8cA&slotNum=5&s=hi&ie=UTF8&qid=1505166922&sr=1-2&keywords=siren+driver&linkCode=w61&tag=konnected-io-20&linkId=0824dcf3d90604bfe1f1f062c7d1d9bc)[Siren Driver 2 Channel 6-12Vdc](https://aax-us-east.amazon-adsystem.com/x/c/QnhZYhXwaxo3MpuOcRfVJDUAAAFiMJ_-aAEAAAFKAehtpwg/https://www.amazon.com/Siren-Driver-2-Channel-6-12Vdc/dp/B003XZZ3WO/ref=as_at/?creativeASIN=B003XZZ3WO&imprToken=vLJECtX1jTllzS5HNcy8cA&slotNum=6&s=hi&ie=UTF8&qid=1505166922&sr=1-2&keywords=siren+driver&linkCode=w61&tag=konnected-io-20&linkId=3cec81f685352663a55f473724636f65)
