MQTT Client: Configuring Konnected as a MQTT client in ESPHome
Konnected devices can talk to a multitude of systems over the standardized MQTT protocol
    MQTT Configuration using ESPHome
    Konnected hardware can integrate with any platform that speaks MQTT by leveraging the ESPHome firmware. With Konnected + ESPHome you can combine Konnected's high-quality hardware with the power and flexibility of local and secure MQTT communication.
    MQTT enables powerful integration with services like Node-RED, Homeseer, Domoticz and more.
    See the ESPHome MQTT documentation for complete details. A simple MQTT connection only requires a broker address (and probably username/password).
    mqtt:
    broker: 192.168.1.78
    discovery: False # remove if using MQTT with Home Assistant
    username: mqtt_username
    password: !secret mqtt_password
    State Topics
    By default, ESPHome will publish ON or OFF state payloads to an MQTT topic following this pattern: APP_NAME/COMPONENT_TYPE/COMPONENT_NAME/state
    Example state topic:  my_konnected/binary_sensor/zone_1/state
    Command Topics
    Switch zone types will respond to ON or OFF payloads published to a topic following this pattern: APP_NAME/COMPONENT_TYPE/COMPONENT_NAME/command
    Example command topic:  my_konnected/switch/siren/command
