title: Mapping Konnected Zones to Control4 Devices
description: After setting up a Konnected Alarm Panel in Control4, each input zone is available as an output in Control4 to be connected to input devices.
[Skip to content](https://support.konnected.io/mapping-konnected-zones-to-control4-devices#main-content)
2. [Control4](https://support.konnected.io/control4?hsLang=en)
# Mapping Konnected Zones to Control4 Devices
### Use Konnected sensors in Control4
**New in 2024!** Konnected GDO's ([White v2](https://konnected.io/products/smart-garage-door-opener), and [blaQ](https://konnected.io/products/smart-garage-door-opener-blaq-myq-alternative)) now integrate with Control 4. The driver was developed by Chowmain Software, and it can be purchased from their website [here](https://chowmain.software/).
After [setting up a Konnected Alarm Panel in Control4](https://support.konnected.io/discover-setup-konnected-alarm-panels-in-control4?hsLang=en), each input zone is available as an output in Control4 to be connected to input devices. This step-by-step example will connect Konnected's Zone 1, which we named "Front Door" to a door sensor in Control4.
1. In Composer Pro, select the *My Drivers* or *Search* tab in the right-most pane, and navigate or search for *Door Sensor* under the *Sensors* folder. Most generic sensor types in Control4 will work with Konnected sensor zones. Double-click on the sensor type to add an instance to the project.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32013013101originalzhJMzP1kwq9K_mFC44xGeYsQBo7SwVC0Cw.png)](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/32013013101/original/zhJMzP1kwq9K_mFC44xGeYsQBo7SwVC0Cw.png?1666737394)
2. Expand the *Connections* pane in the left-most panel, and click on the sensor instance that was just created. This will show the *Input* for this sensor instance and available *Outputs* from Konnected zones in the pane below.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32013013102original2b5p_2dtLOTTek3xe3Xd08J0CVXyB-kcSA.png)](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/32013013102/original/2b5p_2dtLOTTek3xe3Xd08J0CVXyB-kcSA.png?1666737452)
3. Drag the Alarm Panel zone output in the lower pane to the sensor input in the upper pane. The interface shows that they are connected to each other.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32013013308original89deZbym_P7Xi0YWjj_7AepSi7le7kHBVg.png)](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/32013013308/original/89deZbym_P7Xi0YWjj_7AepSi7le7kHBVg.png?1666749334)
4. Rename the sensor to the name of your zone or however you want it to appear in the Control4 app interface by right-clicking on the sensor instance in the System Design pane.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32013013309original81aC59ohrOWicx0WjlN2vCyYhKfZIYVKiQ.png)](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/32013013309/original/81aC59ohrOWicx0WjlN2vCyYhKfZIYVKiQ.png?1666749419)
5. Select *Refresh Navigators* from the *File* menu to refresh the Control4 app user interface and the device should now appear with a proper icon.
   [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32013013310originalmof003b7IZqYmP4YumYDPBHv6KIhJ2wGAA.png)](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/32013013310/original/mof003b7IZqYmP4YumYDPBHv6KIhJ2wGAA.png?1666749576)
