title: Alarm Panel Pro - Technical Specifications
description: Konnected Alarm Panel Pro technical specifications
[Skip to content](https://support.konnected.io/konnected-alarm-panel-pro-technical-specifications#main-content)
3. [Alarm Panel Pro: Hardware & Firmware](https://support.konnected.io/alarm-panel?hsLang=en#alarm-panel-pro-hardware-firmware)
# Alarm Panel Pro - Technical Specifications
💡 Also see: [**Inputs & Outputs**](https://support.konnected.io/alarm-panel-pro-inputs-and-outputs?hsLang=en) for an illustrated description of all the connections on the board.
### Product Info
- Product Name: Konnected Alarm Panel Pro (Kit)
- Product SKUs:
    - PCB-ALARM-PANEL-PRO (Alarm Panel Pro board only)
    - KIT-ALARM-PANEL-PRO (Conversion kit)
    - KIT-ALARM-PANEL-PRO-INF (Interface kit)
- Hardware Version: 1.x
- Accessories Included (with Conversion or Interface kit):
    - 12V 2.5A DC Power Adapter
    - Adhesive-backed standoffs
    - Piezo buzzer and jumper wires
    - Wire labels sheet
    - Konnected logo sticker and window sticker
    - Mini screwdriver-pen
- Accessories included (with Interface kit):
    - 2x Konnected Alarm Panel Interface modules
    - 2x ribbon cables
### Power
- Recommended Input Power: 12V DC 2.5A via DC barrel jack
- Power-over-Ethernet (PoE): Compatible with PoE+ 802.3at equipment
- PoE max current provided: 1A
- Included Power Adapter: 12VDC 2.5A
- Power Adapter Plug Type: US / EU / UK / AU (depending on country)
- Input Power Acceptable Range: 6V - 24V DC
- AUX Power output: Pass-thru from input power source
- Device may be powered via barrel jack OR AUX power terminals (they are electrically  connected)
- **DC Power Only!**
### Wireless Networking
- 802.11 b/g/n 2.4GHz Wi-Fi
- Wireless microcontroller: ESP32-WROOM-32D (Espressif) \[[datasheet](https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32d_esp32-wroom-32u_datasheet_en.pdf)\]
- RF Certification: \[[manufacturer's link](https://www.espressif.com/en/support/documents/certificates?keys=ESP32-WROOM-32D)\]
- Wi-Fi Security: WPA/WPA2/WPA2-Enterprise/WPS
- Wi-Fi Frequency Range: 2412 ~ 2484MHz (regional-specific frequency range is configurable in software)
- Wi-Fi Transmit Power:
    - Min: 12; Typical: 13; Max: 14 dBm (802.11n, MCS7)
    - Min: 17.5; Typical: 18.5; Max: 20 dBm (802.11b)
- Antenna: Internal PCB antenna
- Bluetooth v4.2 BR/EDR and BLE specification
- Bluetooth radio: Class-1, class-2 and class-3 transmitter
- Encryption: AES/RSA/ECC/SHA
- FCC ID: 2AC7Z-ESPWROOM32D
- Industry Canada ID: 21098-ESPWROOM32D / CAN ICES-3
### Wired Networking
- Ethernet: Fast Ethernet 10/100
- Ethernet connector: Standard RJ45
- PoE+ capable (see *Power* above)
### Sensor Inputs (Zones 1-12)
- Detects an open/closed loop
- Works with: Magnetic door contacts, mechanical door contact sensors, limit switch sensors, PIR motion sensors (with dry-contact signal), any dry-contact or open collector circuit.
- Resistant to EMI and transient electrical surges caused by nearby lightning
- Programmable as binary (high/low) outputs: Zones 1-8
- Output voltage: 3.3V
### Alarm Outputs
#### ALRM1 & ALRM2
- Output voltage: Same as input voltage or 12V when using PoE
- Output current maximum: 2A
- Negative switched
### Trigger Outputs
#### OUT 1 & OUT 2
- Output voltage: 3.3V DC
- Output current maximum: 12mA
### 5V AUX Output
#### Pins +5V
- Output voltage: 5V DC
- Output current maximum: 300mA (combined)
### USB
- USB port is provided for firmware servicing
- Micro-USB Type B
- Not intended for supplying power during prolonged operation
### Dimensions
[Alarm Panel Pro dimensions diagram - PRINTABLE PDF](https://support.konnected.io/hubfs/ALARM%20PANEL%20PRO%20Dimension%20Drawing.pdf?hsLang=en)
### Compliance
- [EU Declaration of Conformity](https://support.konnected.io/hubfs/EU_DoC_CE_APP-01.docx__EU_DoC_CE_APV2-01.docx.pdf?hsLang=en)
- [Intertek test report](https://drive.google.com/file/d/1KSJpecBz1sQXTd777jlU4WlydmrkTUM2/view?usp=share_link)
