title: Konnected Alarm Panel Pro Conversion Kit Installation and Setup Guide
description: "The Konnected Alarm Panel Pro Conversion Kit: Make Your Existing Old School Alarm System Smart"
[Skip to content](https://support.konnected.io/konnected-alarm-panel-pro-conversion-kit-installation-guide#main-content)
3. [Installation Guide Table of Contents](https://support.konnected.io/alarm-panel?hsLang=en#installation-guide-table-of-contents)
# Konnected Alarm Panel Pro Conversion Kit Installation and Setup Guide
## The Konnected Alarm Panel Pro Conversion Kit: Make Your Existing Old School Alarm System Smart
This guide will assist you in upgrading your existing wired alarm system with the Konnected Alarm Panel **Pro Conversion Kit**. The Pro Kit offers enhanced connectivity through Ethernet and PoE options, providing a more reliable and flexible integration with smart home platforms. This outline contains a suggested sequential series of steps with brief instructions on page as well as links to more comprehensive instructions for each step.
**Product Information        1**
### **Key Features and Benefits**
- **Enhanced Connectivity:** Offers Ethernet and PoE options for more stable and versatile network connections.
- **User-Friendly Installation:** Easy installation process, similar to the standard kit, for a quick system upgrade.
- **No Installer Code Needed:** Simplifies setup without requiring specialized access codes.
- **Seamless Integration:** Works with existing sensors and sirens, ensuring a hassle-free transition to smart functionality.
- **Advanced Automations:** Leverage existing sensors for intelligent automations, enhancing both security and convenience.
- **Scalable System:** Modular design that accommodates your home’s evolving security requirements.
- **Universal Access:** Allows unlimited user access for easy monitoring and control by all household members.
### Important Information
- **Keypad Compatibility:** Traditional keypads become inactive; consider modern alternatives like wall-mounted tablets.
- **Monitoring Options:** Professional monitoring isn't supported natively, but U.S. customers can use Internet-based services like Noonlight.
### **What’s in the Box?**
Your Konnected Alarm Panel Conversion Kit includes the following items:
![Konnected Alarm Panel Pro Conversion Kit](https://support.konnected.io/hs-fs/hubfs/Konnected%20Alarm%20Panel%20Pro%20Conversion%20Kit.webp?width=670&height=670&name=Konnected%20Alarm%20Panel%20Pro%20Conversion%20Kit.webp)
- 12-Zone Alarm Panel Pro
- 12V Power Adapter
- Piezo Buzzer
- Jumper Wires
- Adhesive-backed Mounting Standoffs
- Mini Screwdriver-pen
- Wire Labels Sheet
- Konnected Window Stickers
- Welcome card containing instructions and information
**Table of Contents        2**
### **Setup Overview**
The following steps provide an overview of the steps involved in the setup of your Konnected Alarm Panel Conversion Kit:
- [Connecting to Your Network](https://support.konnected.io/connecting-to-your-network-for-pro-boards?hsLang=en) - (Detailed instructions)
    - ### **Connecting to Your Network**
      #### Method #1: Konnected Mobile App (Recommended)
          - Download: Get the Konnected app for iOS or Android.
          - scan the code below for iOS
            ![adobe-express-qr-code](https://support.konnected.io/hs-fs/hubfs/adobe-express-qr-code.png?width=150&height=150&name=adobe-express-qr-code.png)
          - scan the code below for android
            ![adobe-express-qr-code (1)](https://support.konnected.io/hs-fs/hubfs/adobe-express-qr-code%20(1).png?width=150&height=150&name=adobe-express-qr-code%20(1).png)
          - Plug in the Ethernet Port to your router.
          - Power one Konnected board (steps will be repeated for additional boards) with the included power supply.
- - - Launch: Start the app and select 'Add New Device'.
          - Tap 'Scan' - the board should be seen in the app
          - Multiple Boards: Repeat for each board you have.
          - #### NOTE: if you need the board on wifi the board will require a firmware update that can be done through the Konnected mobile app (under the Connection drop-down in Settings)
- [Identifying Your Wiring](https://support.konnected.io/identifying-your-wiring-1?hsLang=en)
    - ### **Identifying Your Wiring**
      Proper identification and labeling of your existing wiring are paramount for successfully installing the Konnected Alarm Panel Conversion Kit. Follow these steps to ensure accuracy:
      #### **Documentation**
          - Photograph Your Setup: Capture high-quality images of your current alarm panel, wiring, and any zone lists or diagrams you have.
      **Labeling**
          - Use Provided Labels: Apply the included label stickers to each wire, noting their corresponding connections for easy reference.
      #### **Wire Identification**
          - Recognize Wire Types: For a comprehensive guide on wire labels such as AC +/-, Aux +/-, Bell +/-, Data, Zones, and Telephone, please refer to our detailed [📄 Identifying Your Wiring documentation](https://support.konnected.io/identifying-your-wiring-1?hsLang=en).
                  - 2-Strand Wires: Typically used for sensors.
                  - 4-Strand Wires: Commonly connect motion detectors and keypads.
                  - Red/Black Wires: Usually indicate power connections.
      **AC Power Caution:** Never attach AC power wires directly to the Konnected board.
- [Mounting and Positioning](https://support.konnected.io/mounting-positioning?hsLang=en)
    - ### **Mounting and Positioning**
      #### **Location**
          - Near Existing Wiring: Install the Konnected Panel, which can easily connect to your wired sensor wires or the original wiring panel.
      #### **Enclosure Options**
          - 3D Printed Enclosure: Consider a tailored enclosure for a secure and neat fit.
          - Reuse Metal Enclosure: Alternatively, you may repurpose the enclosure of your old system. *We've found that WiFi signal interference from metal enclosures is often insignificant.*
      #### **Installation**
          - Mounting Options: Secure the device using magnetic or adhesive standoffs.
          - WiFi Proximity: Position the panel within a good range of your router to ensure a robust WiFi signal.
          - Interference Precautions: Avoid placing the device near high-voltage wiring to minimize potential interference.
- Wiring Your Sensors and Sirens:
    - [Door and Window Sensors](https://support.konnected.io/wiring-your-window-and-door-sensors?hsLang=en)
          - ### **Wiring Your Door and Window Sensors**
            #### **Introduction**
            When setting up your Konnected Alarm Panel Conversion Kit, it's important to connect your door and window sensors correctly. These instructions will guide you through the process.
            #### **Sensor Types**
                  - Normally Closed (NC) Circuits: These sensors are inactive (closed) when the door/window is closed and active (open) when the door/window is opened.
            #### **Connection Steps**
                  - Zone and Ground: Attach each sensor's two wires to a zone and the ground (GND) terminal on the Konnected board.
                  - Serial Connection: For multiple sensors in a series, link an end-of-line resistor between the last sensor and the return wire to the panel.
            #### **Important Notes**
                  - All Doors and Windows: Verify they are closed before testing your setup.
                  - Avoid AC Power: **Do not** connect any AC power wires to the Konnected board.
                  - Bench Test: It's recommended to test the setup with your smart home platform before final installation.
- - [Motion Sensors](https://support.konnected.io/wiring-your-motion-sensors?hsLang=en)
          - ### **Wiring Your Motion Sensors**
            To integrate motion sensors with the Konnected Alarm Panel Conversion Kit, follow these instructions carefully:
            #### **Connections**
                  - Power Connection:
                            - Red Wire: Connect from the sensor to the AUX+ terminal on the Konnected board.
                            - Black Wire: Connect to the AUX-.
                  - Signal Connection:
                            - One Wire: From the sensor’s alarm circuit, attach to a zone terminal on the Konnected board.
                            - Second Wire: Attach to the GND terminal.
                  - For Multiple Sensors:
                            - Each motion sensor requires a separate zone terminal.
    - [Sirens/Strobes](https://support.konnected.io/wiring-a-siren?hsLang=en)
          - ### **Wiring Your Siren**
            Connect your siren to the Konnected Alarm Panel Conversion Kit with these steps for a secure and functional setup:
            #### **Connection Guide**
                  - Positive Terminal: Attach the siren's positive (red) wire to the 'OUT' terminal on your Konnected board.
                  - Negative Terminal: Connect the siren's negative (black) wire to the 'GND' terminal.
            #### **Power Specifications**
                  - Ensure the siren's power rating does not exceed 2A (ampere) and 20W (watt).
                  - For 12V sirens: These can be powered directly from the board without additional power sources.
- - [Piezo Buzzer](https://support.konnected.io/wiring-a-piezo-buzzer?hsLang=en)
          - ### **Wiring Your Piezo Buzzer**
            Connect a piezo buzzer to your Konnected Alarm Panel Pro Conversion Kit efficiently by following these instructions:
                  - Dedicated Output: Utilize the dedicated output on the Pro board for the piezo buzzer connection.
                  - Output Zones: You may connect the buzzer to any of the zones 1-5 on the alarm panel board as these can function as outputs.
            #### **Wiring Steps**
                  - Positive Wire: Attach the positive wire of the buzzer to the 'OUT' terminal.
                  - Negative Wire: Connect the negative wire to the 'GND' terminal.
- - [Smoke and Carbon Monoxide Detectors](https://support.konnected.io/smoke-carbon-monoxide-detectors?hsLang=en)
          - PLEASE SEE DETAILED GUIDE VIA THE LINK ABOVE FOR SMOKE AND CARBON MONOXIDE DETECTOR WIRING INFORMATION
    - [Glass Break Sensors](https://support.konnected.io/wiring-glass-break-sensors?hsLang=en)
          - ### **Wiring Glass Break Sensors**
            Ensure the safety of your premises by correctly wiring glass break sensors to the Konnected Alarm Panel Conversion Kit.
                  - Zone Connection: Attach the glass break sensor's wires to any available zone on the Konnected board.
                  - Circuit Behavior: Understand that most glass break sensors operate on a Normally Closed (NC) circuit, which will open in response to the sound of breaking glass.
            #### **Power Supply**
                  - Power the sensor using the AUX power terminals on the Konnected board, according to the sensor's specifications.
- - [Relays](https://support.konnected.io/wiring-a-relay?hsLang=en)
          - ### **Wiring a Relay**
            Integrate relays with your Konnected Alarm Panel to add smart control to household devices like sprinkler systems or garage door openers.
            #### **Steps for Connection**
                  - Attach 5V Power: Connect the 5V pin from the add-on or Pro board to the relay's VCC or DC+.
                  - Ground Connection: Link the GND pin on the board to the GND or DC- on the relay.
                  - Output Signal: For the relay's input, connect the OUT pin to IN on the relay.
                  - High-Power Devices: For devices requiring 12V, such as alarms or lights, utilize the ALARM +/- terminals on the main board.
            #### **Configuration Tips**
                  - Ensure most Konnected relays are set to 'low-trigger' for compatibility with your smart home app settings.
- [Powering Your Konnected Board(s)](https://support.konnected.io/powering-your-konnected-board?hsLang=en)
    - ### **Powering Your Konnected Board**
      Choose from multiple power supply options to ensure your Konnected Alarm Panel operates efficiently.
      #### **Powering Options**
          - Existing Alarm System: Utilize the 12V DC power from your previous alarm system's power supply.
          - Board Specifications: The board is compatible with a range of 6V to 24V DC or 5V via USB.
          - Included Power Adapter: Plug the included power adapter into a standard outlet for a simple setup.
          - USB Powering: While USB is an option for board power, it won't support high-draw devices like sensors or sirens.
          - Multiple Boards: Utilize a splitter cable if you're setting up multiple boards.
          - Reusing Wiring: If repurposing existing wiring, first ensure to disconnect the old system's power and battery.
- [Choosing Your Smart Home Platform](https://support.konnected.io/choose-your-smart-home-platform?hsLang=en)
After the initial setup, you'll be able to seek support and join the Konnected community for additional help and inspiration.
#### **Support and Resources**
Should you encounter any issues, reach out for support:
- Submit a ticket or email us at [help@konnected.io](mailto:help@konnected.io).
- Join our [community forums](https://community.konnected.io/) for questions, support from other users, and inspiration.
