Hubitat (legacy driver): Device Discovery
This article refers to legacy drivers for the Konnected Alarm Panel and Alarm Panel Pro. This integration is deprecated and should not be used for new installations!
New installs: See Connecting the Alarm Panel to Hubitat (ESPHome)
Now that you’ve installed the Konnected Apps and Drivers, you can begin adding the Konnected devices to Hubitat. Note that your Hubitat hub must be connected to the same internal network as the Konnected device(s).
- Open your Hubitat dashboard and click on Apps on the menu bar and then click Add User App
- Scroll all the way down to Konnected (Connect) under the User Apps heading and click it.
- Click on Add a Konnected device.
- Click on Tap here to start discovery.
- Within a few seconds you should see one of the Konnected devices discovered. Click on it.
This process discovers one device at a time. If you have multiple Konnected boards, repeat these steps after finishing setup.
Next Step: Setup Sensors and Devices
