title: How is the Smart Garage Door Opener different from using a momentary switch with a relay?
description: Is the Garage Door Opener similar to a momentary switch?
[Skip to content](https://support.konnected.io/how-is-the-smart-garage-door-opener-different-from-using-a-momentary-switch-with-a-relay#main-content)
2. [Frequently Asked Questions (FAQ)](https://support.konnected.io/frequently-asked-questions-faq?hsLang=en)
3. [Garage Door Opener](https://support.konnected.io/frequently-asked-questions-faq?hsLang=en#garage-door-opener)
# How is the Smart Garage Door Opener different from using a momentary switch with a relay?
## Is the Garage Door Opener similar to a momentary switch?
The Smart Garage Door Opener works similarly. The Smart Garage Door Opener product uses a relay to trigger the door to open and close. It also has an optical sensor to see if the door is open without needing a wired contact sensor. It also supports a wired contact sensor.
In short -- similar technology, just a more streamlined purpose-built product. In SmartThings, it shows up as a Garage Door entity instead of a separate device for the switch and sensor.
