title: "ESPHome: Customize Zone Inputs on Konnected Alarm Panels"
description: Use all the input and output features of ESPHome on your Konnected Alarm Panel device.
[Skip to content](https://support.konnected.io/esphome-customize-zone-inputs-on-konnected-alarm-panel#main-content)
2. [ESPHome](https://support.konnected.io/esphome?hsLang=en)
3. [ESPHome](https://support.konnected.io/esphome?hsLang=en#esphome)
# ESPHome: Customize Zone Inputs on Konnected Alarm Panels
## How to change zone types and settings in ESPHome and use different types of sensors and outputs
By default, Konnected's ESPHome builds set up each *zone* on the Konnected Alarm Panel as a basic binary input. *Binary* means that it has two states: open/closed or detected/not-detected.
This article will show you how to customize the zones for different use cases.
**📖 Required Reading:** [Adopting an ESPHome device](https://support.konnected.io/adopt-an-esphome-device-into-esphome-dashboard?hsLang=en) and [ESPHome customization basics](https://support.konnected.io/esphome-firmware-customization-basics?hsLang=en).
### Binary Sensor Inputs
Konnected's ESPHome builds define entity IDs named *zone1* thru *zone6* on the [6-zone boards](https://github.com/konnected-io/konnected-esphome/blob/master/alarm-panel-esp8266.yaml) and *zone12* on the [Alarm Panel Pro.](https://github.com/konnected-io/konnected-esphome/blob/master/alarm-panel-pro-esp32-ethernet.yaml#L95)
Konnected's default binary sensor configuration sets up a basic input zone that can has limited customization in Home Assistant (name, device class, and icon). For more advanced customizations, you can use the *!extend* keyword to extend functionality.
#### Changing the Name and/or type of a Zone
You can rename zones and set the device class in the Home Assistant UI, or extend the zone configuration and [override the name and device\_class](https://esphome.io/components/binary_sensor/index.html#base-binary-sensor-configuration) so that your zone configuration is saved in the firmware. This example renames Zone 3 to "Upstairs Windows" and sets Zone 4 as a motion sensor called "Downstairs":
binary_sensor:  - id: !extend zone3    name: Upstairs Windows    device_class: window  - id: !extend zone4    name: Downstairs    device_class: motion
#### Inverting a Sensor
You may need to invert a sensor if the states are reversed, for example a smoke detector that is normally open, by extending the config and setting *inverted* to true like this:
 binary_sensor:  - id: !extend zone3    name: Smoke Alarm    device_class: smoke    pin:      inverted: true
#### Prevent "Flickering" State Changes or Debouncing
Sometimes a contact sensor will open and close a few times very fast when moving, so to prevent many rapid state changes we use a [*debouncing* filter](https://esphome.io/components/binary_sensor/gpio.html#debouncing-values). By default this is set to 200 milliseconds. You can adjust it globally:
substitutions:  sensor_debounce_time: 500ms
Or individually overriding a specific input zone:
binary_sensor:  - id: !extend zone1    filters:      - delayed_on_off: 500ms
