ESPHome: Customization on the Garage Door Opener
How to customize your Konnected Garage Door Opener with Konnected's ESPHome packages
This article applies to the Garage Door Opener running ESPHome firmware.
Plug-and-Play with Home Assistant Using Konnected's ESPHome Firmware
Konnected's pre-built firmware for our Garage Door Opener lets you quickly automate your garage door opener with Home Assistant with the most common simple setup. The optical laser sensor is used to detect the open garage, and the DOOR relay toggles it. A 5-second audible and visual warning is built-in.
When you adopt a Konnected Garage Door Opener into your ESPHome config, the default configuration looks like this:
substitutions:
packages:
  konnected.garage-door-esp8266: github://konnected-io/konnected-esphome/garage-door-esp8266.yaml@master
esphome:
  name_add_mac_suffix: false
api:
  encryption:
  key: UNIQUE_GENERATED_KEY_FOR_HOME_ASSISTANT
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
The package konnected-esphome/garage-door-esp8266.yaml hosted on GitHub is Konnected's open-source default package of Garage Door Opener firmware configurations with in-line comments to help you understand what each package does.
Changing Garage Door Opener Settings
Most settings can be adjusted by overriding variables in the substitutions section of your config.
Changing the Garage Door Relay Duration
By default, the relay to trigger the garage door closes for 300ms (0.3 seconds). To change this:
substitutions:
 garage_door_opener_momentary_duration: 500ms
Changing the Warning Duration
By default, a 5-second audible and visual warning occurs before the garage door closes.
substitutions:
 garage_door_close_warning_duration: 10s
Changing the Optical Laser Range Sensor Margin of Error
By default, the device allows for a +/- 0.1m (10cm) margin of error when seeing if the open garage door is visible at the calibrated distance. Adjust this (in meters):
substitutions:
 open_garage_door_distance_margin_of_error: "0.15"
Customizing the Wired Sensor Input
The wired sensor input is enabled via packages/garage-door-wired-sensor.yaml and sets up an internal binary sensor with id garage_door_wired_sensor. It can be customized to function in many ways:
Make the Wired Sensor Available in Home Assistant
To expose the wired sensor as a separate entity in Home Assistant, add this to your config to override the default binary sensor config:
binary_sensor:
- id: !extend garage_door_wired_sensor
name: My Wired Sensor
internal: false
Use the Wired Input for a PIR Motion Sensor
Don't need a wired garage door sensor? Add a 360-degree PIR Motion Sensor in the garage instead!
binary_sensor:
internal: false
device_class: motion
Extended Configuration for Customizing Packages
To customize the firmware, you can pick and choose from the packages that you want. To do this, follow the link above to the default package on GithHub, and copy and paste the contents of that file into your ESPHome config, replacing everything except your substitutions section, like this (comments removed for brevity):
substitutions:
packages:
  remote_package:
    url: http://github.com/konnected-io/konnected-esphome
  ref: master
    files:
      - packages/garage-door-esp8266-base.yaml
    - packages/garage-door-cover-range.yaml
    - packages/garage-door-wired-sensor.yaml
    - packages/vl53l0x-range-sensor.yaml
    - packages/garage-door-opener-button.yaml
    - packages/switch.yaml
    - packages/warning-led.yaml
    - packages/warning-beep.yaml
    - packages/wifi.yaml
    - packages/status-led.yaml
esphome:
api:
  encryption:
wifi:
web_server:
logger:
ota:
Using a Wired Sensor with the Optical Range Sensor
To add a wired sensor in addition to the optical laser range sensor to know if the garage is open or closed, replace the cover pcakge with packages/garage-door-cover-wired-and-range.yaml.
This package combines the states of both sensors, showing the garage door as open when either sensor shows open, and closed when both sensors show closed.
substitutions:
packages:
  remote_package:
    ref: master
    files:
    - packages/garage-door-cover-wired-and-range.yaml
esphome:
api:
  encryption:
wifi:
web_server:
logger:
ota:
Using a Wired Sensor Instead of Optical Range Sensor
To rely on the wired sensor instead of the optical laser range sensor to know if the garage is open or closed, replace the cover package with packages/garage-door-cover-wired.yaml.
To disable the range sensor completely, you can remove or comment out the vl53l0x-range-sensor.yaml
substitutions:
packages:
  remote_package:
    ref: master
    files:
    - packages/garage-door-cover-wired.yaml
    # - packages/vl53l0x-range-sensor.yaml
esphome:
api:
  encryption:
wifi:
web_server:
logger:
ota:
