title: Discover Using the Konnected Mobile App
description: Get started with SmartThings by discovering your devices with the Konnected Mobile App for discovery and setup.
[Skip to content](https://support.konnected.io/discover-using-the-konnected-mobile-app#main-content)
2. [SmartThings](https://support.konnected.io/smartthings?hsLang=en)
# Discover Using the Konnected Mobile App
## Get started with SmartThings by discovering your devices with the Konnected Mobile App for discovery and setup.
**Konnected Cloud** enables integration with SmartThings without needing a hub or additional hardware!
This section will guide you through using the Konnected mobile app to discover, set up, and provision your Konnected device(s).
1. Download & install the Konnected mobile app from the [Apple App Store](https://apps.apple.com/us/app/konnected-smart-home/id1476783562) or the [Google Play Store](https://play.google.com/store/apps/details?id=io.konnected.konnected).
   <https://apps.apple.com/us/app/konnected-smart-home/id1476783562?mt=8>[![Download\_on\_the\_App\_Store\_Badge\_US-UK\_RGB\_blk\_092917](https://support.konnected.io/hubfs/Download_on_the_App_Store_Badge_US-UK_RGB_blk_092917.svg)](https://apps.apple.com/us/app/konnected-smart-home/id1476783562) [![Get it on Google Play](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)](https://play.google.com/store/apps/details?id=io.konnected.konnected&pcampaignid=MKT-Other-global-all-co-prtnr-py-PartBadge-Mar2515-1)<https://apps.apple.com/us/app/konnected-smart-home/id1476783562>
2. Plug in the device(s) using the included power adapter. Let them connect to your network (the blue light should blink a few times and then turn off) **(NOTE: This step assumes that you have already followed the steps for "[Connecting to Your Network](https://support.konnected.io/connecting-to-your-network?hsLang=en)")**
   \- *We recommend powering only one module at a time to make it easier to know which device you are connecting to. Then label the module, so you know which it is.*
3. Your mobile phone should be connected to the same WiFi network as the Konnected device(s). Tap *Scan Now* to discover the Konnected device(s) on the network.
   ![Untitled (16)](https://support.konnected.io/hs-fs/hubfs/Untitled%20(16).png?width=323&height=700&name=Untitled%20(16).png)
   After a few seconds, the Konnected devices found on your network will appear in a list.
   <https://help.konnected.io/en/support/solutions/articles/32000023644-device-discovery-troubleshooting>
4. Tap on each device in the list one at a time (devices initially shows up as *konnected-xxxxx*). You can see the device's status and change the name if desired from this screen.
   \- *Software updates, if available, will also appear here with a prompt to update automatically.*
**Next Step:** [Provision Device in Konnected Cloud](https://support.konnected.io/provision-a-device-in-konnected-cloud?hsLang=en)
**Troubleshooting**
[Device Discovery Troubleshooting](https://support.konnected.io/device-discovery-troubleshooting?hsLang=en)
[Connecting to WiFi](https://support.konnected.io/connecting-to-your-network?hsLang=en)
