title: Backup Batteries for Google WiFi
description: According to Google's specifications, the Google WiFi devices use a 5V USB-C power adapter and consume ~9W (1.8A).  You can use the Konnected WiFi Router Backup Battery to protect your Google WiFi from power outages, but you'll need some additional cables.
[Skip to content](https://support.konnected.io/backup-batteries-for-google-wifi#main-content)
2. [Accessories](https://support.konnected.io/accessories?hsLang=en)
3. [Backup Batteries](https://support.konnected.io/accessories?hsLang=en#backup-batteries)
# Backup Batteries for Google WiFi
According to [Google's specifications](https://support.google.com/wifi/answer/6280668?hl=en), the Google WiFi devices use a 5V USB-C power adapter and consume ~9W (1.8A).
You can use the Konnected WiFi Router Backup Battery to protect your Google WiFi from power outages, but you'll need some additional cables. You would need a [USB-C cable](http://amzn.to/2Cj6z8b) to connect the battery's USB port to the Google WiFi. You will also need a [12V 2A power adapter](http://amzn.to/2BpYUrL) for the input power to the battery, as the power adapter that comes with the Google WiFi is not suitable for charging the battery.
### Recommend Accessories on Amazon
| [![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/ws-na.amazon-adsystem-2.comwidgetsq)](http://amzn.to/2BtivaD) | [UL Listed 12V 2A power adapters](http://amzn.to/2BtivaD) for keeping the battery charged. The Power adapter that comes with Google Wifi is not suitable for charging the battery. |
