title: Arming and Disarming with Presence Sensors
description: A “Smart” security system is different from the traditional alarm system panel that you’re used to that requires manually arming and disarming the system using a keypad.
[Skip to content](https://support.konnected.io/arming-and-disarming-with-presence-sensors#main-content)
2. [SmartThings](https://support.konnected.io/smartthings?hsLang=en)
# Arming and Disarming with Presence Sensors
A “Smart” security system is different from the traditional alarm system panel that you’re used to that requires manually arming and disarming the system using a keypad. The best way to use your new Smart Home Monitor system is to automatically arm and disarm the system as you come and go based on *presence*. To set this up, configure Routines to set Smart Home Monitor to *Armed (Away)* when the *Goodbye* routine is triggered and *Disarmed* when the *I’m Back* routine is triggered. [You can then automate the triggering of these routines with Everyone Leaves and when Someone Arrives.](https://support.konnected.io/automate-arming-and-disarming?hsLang=en)
### Two Way You Smart Home can know you are home
**Phones**
You can set up your phones [using the SmartThings app to act as a presence sensor](https://www.samsung.com/ca/support/apps-services/mobile-presence-smartthings/). You can do this for each adult by [inviting them to your SmartThings account.](https://support.smartthings.com/hc/en-us/articles/206531123-How-do-I-share-my-account-and-manage-users-) This will also allow them to control other smart devices in your home.
**Fob**
Samsung has a [fob that can be used as a presence sensor.](https://www.amazon.com/Samsung-SmartThings-F-ARR-US-2-Arrival-Sensor/dp/B00GM7V8I8/?tag=konnected-io-20) This will work similarly to a phone's presence sensor. Just configure it as a device on your hub.
**Next Step (optional):** [Automate Arming and Disarming](https://support.konnected.io/automate-arming-and-disarming?hsLang=en)
