title: Actuating siren and switches
description: Actuate sirens or switches by sending a JSON payload to the device. Using the REST/HTTP endpoint type
[Skip to content](https://support.konnected.io/actuating-siren-and-switches#main-content)
2. [ESPHome](https://support.konnected.io/esphome?hsLang=en)
3. [Konnected Device API](https://support.konnected.io/esphome?hsLang=en#konnected-device-api)
# Actuating siren and switches
Actuate sirens or switches by sending a JSON payload to the device. Using the REST/HTTP endpoint type, this payload should be a PUT request to **http://\<device-ip\>:\<http-port\>/device**.
When using Amazon Web Services (AWS) IoT, the Konnected device will subcribe to the MQTT topic konnected/DEVICE\_ID/switch where DEVICE\_ID is the 12-character MAC address of the device.
### Examples
#### Turn on a siren
{"pin":8, "state":1}
#### Actuate a momentary switch for 1 second
{"pin":8, "state":1, "momentary":1000}
#### Beep/blink three times
{"pin":8, "state":1, "momentary":65, "times":3, "pause":55}
### Response
When using the REST/HTTP method and a state change is successful, Konnected will respond with a 200 status code and a JSON message indicating the new state.
