title: What's in the box?
description: The GDO blaQ kit comes with everything you need to make your garage opener smart
[Skip to content](https://support.konnected.io/whats-in-the-box-gdo-blaq#main-content)
2. [GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en)
3. [Getting Started with the GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en#getting-started-with-the-gdo-blaq)
# What's in the box?
## The GDO blaQ kit comes with everything you need to make your garage opener smart
Welcome to your new Smart Garage Door Opener blaQ! This guide will walk you through the contents of your package, ensuring you have everything you need for a seamless installation and setup.
### GDO blaQ
![gdo-blaq-angle](https://support.konnected.io/hs-fs/hubfs/gdo-blaq-angle.jpg?width=255&height=170&name=gdo-blaq-angle.jpg)The GDO blaQ itself is obviously the star of the show! Its ABS plastic enclosure and industrial tech design will make it a smart addition to your garage in more ways than one.
![blaQ power adapter](https://support.konnected.io/hs-fs/hubfs/blaQ%20power%20adapter.png?width=212&height=176&name=blaQ%20power%20adapter.png)
### Power Adapter
Essential for powering your GDO blaQ, the power adapter should be plugged into a standard wall outlet near your garage opener motor or wall button. The blaQ ships with a 12V 1A (12W) power adapter with the appropriate plug type for your country.
### Hook-Up Wire
All it takes is two wires — red and white, to connect the GDO blaQ to your garage opener motor or wall button. We include a 1m (~3.3 feet) length of 22-gauge red and white wire, with ends stripped and ready to hook up.
### Mounting Kit
The mounting kit contains two screws and two 3M command strips for permanent or damage-free mounting on the ceiling, wall or garage opener motor itself.
### Mini Screwdriver Pen
![screwdriver 2-1](https://support.konnected.io/hs-fs/hubfs/screwdriver%202-1.jpg?width=241&height=144&name=screwdriver%202-1.jpg)Does the job to tighten the screw terminals and with 4 screwdriver tips included and a ball-point pen on the opposite side, it's also a great addition to your junk drawer.
### Warning Wall Sticker
![warning\_wall\_sticker\_1739221297811-92958f967a-13620234\_21501113\_5x7\_digi\_2000\_1440\_1](https://support.konnected.io/hs-fs/hubfs/warning_wall_sticker_1739221297811-92958f967a-13620234_21501113_5x7_digi_2000_1440_1.png?width=139&height=192&name=warning_wall_sticker_1739221297811-92958f967a-13620234_21501113_5x7_digi_2000_1440_1.png) Required by U.S. consumer product safety regulations, this wall sticker warns occupants that the garage is automated and may move unexpectedly. It also shows off your Konnected brand pride 😉
Affix on the wall near your garage opener wall button.
### Installation Guide
A paper copy of our [full-color GDO blaQ installation guide](https://support.konnected.io/gdo-blaq-quick-start-guide?hsLang=en) is handy for bringing into the garage.
