Smoke & CO Alerts in SmartThings
SmartThings Home Monitor can be used with Konnected to alert and automate when a smoke or CO alarm is triggered.
DO NOT USE KONNECTED FOR CRITICAL FIRE AND LIFE SAFETY
Konnected is NOT designed to alert you in a life-threatening emergency. Alerts and smart home integrations with smoke/fire and CO detectors is for convenience and auxiliary purposes only. ALWAYS have a working smoke/fire/CO alarm with built-in alarm to alert you of a life threatening emergency.
SmartThings Home Monitor will also allow you to set up alerts for your Smoke and CO alarms.
- Start by going to the Life section of the SmartThings app and find SmartThings Home Monitor.
- Tap the Smoke icon (middle icon) to set up the detection
- Select the sensors you want to use (sensors need to be already set up via the Konnected Cloud and linked to SmartThings)
- Select the notification and response you desire
