title: Konnected Smart Garage Door Opener v1 - Technical Specs
description: "Switched output same as input voltage Output Current Maximum: 2A White LED (4000K) blinking light  "
[Skip to content](https://support.konnected.io/konnected-smart-garage-door-opener-technical-specs#main-content)
2. [GDO White](https://support.konnected.io/gdo-white?hsLang=en)
# Konnected Smart Garage Door Opener v1 - Technical Specs
![GDO Product Labels (2)](https://support.konnected.io/hs-fs/hubfs/GDO%20Product%20Labels%20(2).png?width=688&height=401&name=GDO%20Product%20Labels%20(2).png)
### Product Info
- Product Name: Konnected Smart Garage Door Opener Kit
- SKU: KIT-GARAGE-DOOR-OPENER
- Hardware Version: 1.0
- Accessories Included:
    - 12V DC Power Adapter
    - Hookup wire
    - Mounting screws
### Power Supply
- Recommended Input Power: 12V DC 1.5A via DC barrel jack
- Included Power Adapter: 12VDC 1.5A (2A in some countries)
- Power Adapter Plug Type: US / EU / UK / AU (depending on country)
- Input Power Acceptable Range: 6V - 24V DC
- AUX Power terminals: Pass-thru from input power source
- Device may be powered via barrel jack OR AUX power terminals (they are electrically  connected)
- **DC Power Only!**
### **Wireless**
- 802.11 b/g/n 2.4GHz Wi-Fi
- Wireless microcontroller: ESP-12F (Ai-Thinker) \[[datasheet](https://docs.ai-thinker.com/_media/esp8266/docs/esp-12f_product_specification_en.pdf)\]
- WiFi Security: WEP/WPA-PSK/WPA2-PSK
- Frequency Range: 2412 ~ 2484MHz
- Transmit Power:
    - 802.11b: 16±2 dBm (@11Mbps)
    - 802.11g: 14±2 dBm (@54Mbps)
    - 802.11n: 13±2 dBm (@HT20, MCS7)
- Antenna: Internal PCB antenna
- FCC ID: 2AHMR-ESP12F
- Industry Canada ID: 23236-ESP12F
### Sensor Input
- Detects an open/closed loop
- Works with: Magnetic door contacts, mechanical door contact sensors, limit switch sensors, PIR motion sensors (with dry-contact signal), any dry-contact or open collector circuit.
- Resistant to EMI and transient electrical surges caused by nearby lightning
### Door Control Relay
- Dry-contact relay
- Relay Type: SPST-NO (1 Form A)
- Rated Voltage: 0V ~ 60V
- Rated Current: 500 mA
### Strobe Output
- Switched output same as input voltage
- Output Current Maximum: 2A
### Optical Laser Sensor
- Time-of-Flight (ToF) laser-ranging distance sensor
- 940nm VCSEL emitter
- Range: up to 2m
- Class 1 laser device compliant with latest standard IEC 60825-1:2014 - 3rd edition
### USB
- USB port is provided for firmware servicing
- Micro-USB Type B
- Not intended for supplying power during prolonged operation
### Visual Warning
- White LED (4000K) blinking light
### Audible Warning
- Internal piezo buzzer
### Enclosure
- ABS Plastic, injection-molded
### Hookup Wire
- Wire gauge: 24 AWG
- Wire length: approximately 3 meters (~10ft)
