title: GDO blaQ Technical Specs
description: White LED (4000K) blinking light
[Skip to content](https://support.konnected.io/konnected-smart-garage-door-opener-blaq-technical-specs#main-content)
2. [GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en)
# GDO blaQ Technical Specs
![GDO blaQ annotated v2](https://support.konnected.io/hs-fs/hubfs/GDO%20blaQ%20annotated%20v2.png?width=600&height=300&name=GDO%20blaQ%20annotated%20v2.png)
### Product Info
- Product Name: Konnected Smart Garage Door Opener Kit
- SKU: KIT-GDOv2-Q
- Hardware Version: 2.4
- Accessories Included:
    - 12V DC Power Adapter
    - Hookup wire
    - Mounting screws
    - 3M Command Strips
### Power Supply
- Recommended Input Power: 12V DC 1A via DC barrel jack
- Included Power Adapter: 12VDC 1A (2A in some countries)
- Power Adapter Plug Type: US / EU / UK / AU (depending on country)
- Input Power Acceptable Range: 6V - 24V DC
- AUX Power terminals: Pass-thru from input power source
- Device may be powered via barrel jack OR AUX power terminals (they are electrically  connected)
- **DC Power Only!**
### **Wireless**
- 802.11 b/g/n 2.4GHz Wi-Fi
- Bluetooth LE: Bluetooth 5, Bluetooth mesh
- Wireless microcontroller: ESP32-S3-MINI-1 (Espressif) \[[datasheet](https://www.espressif.com/sites/default/files/documentation/esp32-s3-mini-1_mini-1u_datasheet_en.pdf)\]
- WiFi Security: WEP/WPA-PSK/WPA2-PSK/WPA2\_EAP
- Frequency Range: 2412 ~ 2484MHz
- Transmit Power:
    - 802.11b: 20.5 dBm (@11Mbps)
    - 802.11g: 18.0 dBm (@54Mbps)
    - 802.11n: 17.5 dBm (@HT20, MCS7)
- Antenna: Internal PCB antenna
- FCC ID: 2AC7Z-ESPS3MINI1 \[[certificate](https://www.espressif.com/sites/default/files/ESP32-S3-MINI-1%20FCC%20Certification.pdf)\]
- ISED (Canada) ID: 21098-ESPS3MINI1 \[[certificate](https://www.espressif.com/sites/default/files/ESP32-S3-MINI-1%20IC%20Certification.pdf)\]
### Serial GDO data bus
- Specifically designed for Security+ and Security+ 2.0 garage openers
### Auxiliary Inputs 1 and 2
- Detects an open/closed loop
- Or, can be configured as a 3.3V output
- Works with: Magnetic door contacts, mechanical door contact sensors, limit switch sensors, PIR motion sensors (with dry-contact signal), any dry-contact or open collector circuit.
- Resistant to EMI and transient electrical surges caused by nearby lightning
### USB
- USB port is provided for firmware servicing
- Micro-USB Type B
- Not intended for supplying power during prolonged operation
### Visual Warning
- White LED (4000K) blinking light
### Audible Warning
- Internal tonal piezo buzzer
### Enclosure
- ABS Plastic, injection-molded
### Hookup Wire
- Wire gauge: 22 AWG
- Wire length: approximately 3 meters (~10ft)
