title: Get To Know the GDO blaQ physical connections
description: Security+, Security+ 2.0, Chamberlain, myQ and LiftMaster are registered trademarks of The Chamberlain Group, Inc. CRAFTSMAN is a registered trademark of Stanley Black &amp; Decker, Inc.
[Skip to content](https://support.konnected.io/get-to-know-your-gdo-blaq#main-content)
2. [GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en)
3. [Getting Started with the GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en#getting-started-with-the-gdo-blaq)
# Get To Know the GDO blaQ physical connections
## An overview of the connections on the GDO blaQ
![get to know your GDO - blaQ - image 1](https://support.konnected.io/hs-fs/hubfs/get%20to%20know%20your%20GDO%20-%20blaQ%20-%20image%201.png?width=491&height=726&name=get%20to%20know%20your%20GDO%20-%20blaQ%20-%20image%201.png)
| Input Voltage | 5-24VDC (12V recommended) |
| AUX output voltage | Same as input (pass-through) |
| 🔴 Red | Garage opener Security+ 1.0/2.0 communication serial bus |
| ⚪️ White | Ground / common |
| ① and ② | Extra IO can be used for additional contact sensor, motion sensor, relay trigger, etc. |
| USB port | Micro-USB connector |
