title: Extra Input / Outputs ① and ② on the GDO blaQ
description: How to enable and use the Extra IOs labeled ① and ② on the GDO blaQ
[Skip to content](https://support.konnected.io/extra-io-1-and-2-on-the-gdo-blaq#main-content)
2. [GDO blaQ](https://support.konnected.io/gdo-blaq?hsLang=en)
3. [Device Features](https://support.konnected.io/gdo-blaq?hsLang=en#device-features)
# Extra Input / Outputs ① and ② on the GDO blaQ
The GDO blaQ features two additional inputs or outputs that you can enable for a variety of bonus features and capabilities.
### Available Extra Features
1. [Additional open/close sensor (binary sensor)](https://support.konnected.io/extra-wired-sensor-on-the-gdo-blaq?hsLang=en) - Add an extra contact sensor, motion sensor, push-button, or any wired open/close sensor to the garage.
2. [Dry-contact relay](https://support.konnected.io/door-toggle-relay-trigger-on-the-gdo-blaq?hsLang=en)input - Use a relay or an external system to trigger the garage door to toggle.
3. 3V Output - Output a 3.3V current for powering an extra digital sensor
