title: "Alarm Panel & Add-on boards: Identify the board"
description: There are two variations of the Konnected Alarm Panel boards. Both boards support up to 6 zones and a 12V AUX power output. The Alarm Panel board features six zones, AUX power out, and a built-in swit
[Skip to content](https://support.konnected.io/alarm-panel-add-on-boards-identify-the-board#main-content)
3. [6-Zone Alarm Panel & Alarm Panel Add-on (discontinued)](https://support.konnected.io/alarm-panel?hsLang=en#6-zone-alarm-panel-alarm-panel-add-on-discontinued)
# Alarm Panel & Add-on boards: Identify the board
There are **two** variations of the Konnected Alarm Panel boards. Both boards support up to 6 zones and a 12V AUX power output.
### **Konnected Alarm Panel board**
The **Alarm Panel** board features six zones, AUX power out, and a built-in *switched* output for direct connection and control of a siren or strobe.
![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32007739927originaltujNq2Feo6V3COhHb2ZqWynHNoNhFphKiA.png)
1. Expansion port for connecting the [Alarm Panel Interface](https://konnected.io/products/konnected-alarm-panel-interface-module) module.
2. Reboot button. Press once to reboot the device.
3. ESP8266 microcontroller with embededded WiFi antenna.
4. Mounting hole (fits size M3).
5. Reset button. Hold for 10 seconds to erase all settings.
6. Zones 1 - 6 can be used as sensor inputs. Zones 1 - 5 can also be used as 3.3V trigger outputs.
7. Shared ground terminals are labeled with "G".
8. Switched alarm/siren negative. Connect black wire from siren here.
9. Supplies constant AUX power. Connect red wire from siren here.
10. Ground/negative connection for AUX powered devices.
11. Input power 12V - 24V DC.
12. Micro-USB port for servicing firmware or advanced debugging.
### **Konnected Alarm Panel Add-on board**
The **Add-on** board features six zones, AUX power out and a **3.3V signal output** for connecting the piezo buzzer or a relay module. It also has a **5V AUX** output for powering a 5V relay module or [DHT sensor](https://konnected.io/products/temperature-humidity-sensor-module-am2302-dht22) (available separately).
![](https://support.konnected.io/hubfs/Knowledge%20Base%20Import/s3.amazonaws.comcdn.freshdesk.comdatahelpdeskattachmentsproduction32007740110originalYA6W9XnbFL4MDpxeSa7NNtsiRX1nH0Ygag.png)
6. Dedicated OUT zone (3.3V trigger).
7. Zones 1 - 6 can be used as sensor inputs. Zones 1 - 5 can also be used as 3.3V trigger outputs.
8. Shared ground terminals are labeled with "G".
9. Ground/negative connection for AUX powered devices.
10. Supplies constant AUX power positive (same as input voltage).
12. Dedicated OUT zone (same as #6).
13. Shared ground male header.
14. 5V supply for relay (max 500mA).
15. Micro-USB port for servicing firmware or advanced debugging.
**Next Step:** [Connect to Wifi](https://support.konnected.io/connecting-to-your-network?hsLang=en)
